It won't even start now
Discussion in 'General Tech Talk' started by jetdok5, Dec 31, 2011.
0/5, 0 votes
  1. jetdok5
    jetdok5 .040 Over
    73
    Featured Threads:
    11
    21
    8
    warren, ohio
    I just got my 07 in mid November and Have not even had the chance to ride it in good weather. I have about 100 miles since I got it and it seemed to be running fine, then, a little popping thru throttle bodies, dead spot on accell, got worse quick. Made it home, and seemed to have trouble at idle in the garage. I thought it was cold temps, (not really that cold yet). The last time I started it, it did not want to stay running, I added gas because I knew it was low but the light was not on yet....no help. Started it a couple of days later and it was real bad, barely ran and running very rich...very rich. then it quit and will not start now. once in a while one cyl will try but not enough. Cranked the bat dead, recharged, no start, no code light. Hooked uo my OBDII car scanner and it did link but showed no codes.
    Any suggestions?
  2. xhdskip
    xhdskip Living Legend
    Country:
    United States
    5,783
    Media:
    157
    Featured Threads:
    41
    1,583
    813
    North of Tulsa, OKLAHOMA
    Bad TPS in conjunction with a bad battery.
  3. xhdskip
    Country:
    United States
    5,783
    Media:
    157
    Featured Threads:
    41
    1,583
    813
    A hundred dollar harley scorpion battery
    and a hundred dollar TPS should have ya fixed up.
    Triumph might even pop for the TPS if yours is the stock one
    not the "new improved" one.
    I'd get a battery tender too just to keep it charged up.
  4. jetdok5
    jetdok5 .040 Over
    73
    Featured Threads:
    11
    21
    8
    warren, ohio
    I am sure the battery is good, I cranked and cranked and cranked it dead.I did read a lot about the TPS...anyway to test it?
  5. George Todd
    George Todd .020 Over
    19
    0
    1
    West Auckland NewZealand
    Hi I had the same thing with a Honda shadow it played around on the motor way I stoped & it would not start I spent a good 4hrs looking and striping sent it to a bike shop 1hr lab & a new battery all good
  6. atomsplitter
    atomsplitter Nitrous
    Country:
    United States
    1,013
    Featured Threads:
    49
    201
    163
    Scranton, KS
    Replace your TPS. The ECU doesn't deliver fuel without the data from the TPS. Running rich means your TPS is sending the ECU bad data. Your spark plugs are probably fouled from too much gas, clean them (or replace with Iridiums). After that it should run fine.
  7. jetdok5
    jetdok5 .040 Over
    73
    Featured Threads:
    11
    21
    8
    warren, ohio
    Thanks for the advice, is there anywhere to get one other than the dealer??? any cheaper sources? Is there a way to verify?
  8. jetdok5
    jetdok5 .040 Over
    73
    Featured Threads:
    11
    21
    8
    warren, ohio
    And while I am in there, should I pull off the secondary plates or leave well enough alone?
  9. Bluemarlin
    Bluemarlin .040 Over
    Country:
    United States
    59
    Featured Threads:
    2
    15
    8
    you don't need to remove the secondaries if you have tuneboy. You can install a tune that will open the secondaries completely when you shift into first gear.
  10. jetdok5
    jetdok5 .040 Over
    73
    Featured Threads:
    11
    21
    8
    warren, ohio
    Thanks for that advice, I am a little gunshy messing with the mapping, tuneboy is the free one, right?
Loading...
Triumph Rocket III
