CanberraR3
- Joined
- May 27, 2010
- Messages
- 11,317
- Location
- Canberra, Australia
- Ride
- Triumphs, but no Rocket just now.
TORS for a Roadster are 2 slip on mufflers to replace the stock mufflers. They eliminate the cats because on a Roadster they are in the pipes. The "cat box" under the bike is empty and provides the connection and balance. I understand it has some baffling or plates inside for that purpose but no cat. The Staintune connector pipe on a Roadster therefore does not eliminate the cat but provides a freer flowing crossover between the 2 sides.
On a Standard/Classic (3 pipe) system, the cat is in the box, not the mufflers. If you just replace the pipes on these older models with TORS you still have the cat so a cat eliminator is needed. Staintune make a nice free flowing one and Triumph make one that is often referred to as "exhaust upgrade". You can also remove the cat and keep the standard pipes, which several people have done. This provides better flow and a slightly deeper note.
