coneye
.060 Over
I took my bike to have the fork oil changed today , Rocket tourer . Anyway there was nothing wrong with it , just the time frame was up , and i want to keep on top of the bike .
Anyway coming out of his drive , it bottomed out , riding the 3 klm home it was hotrrible its like the front was on a pogo stick , so much so that even my pot belly was wobbling up and down , , i turned into my drive and bang it bottomed out again just going up the little curb from road to driveway .
I rang him he came back with some excuse about there being air in the system , he came round and took the top screw things off and tried pushing the forks up and down ..
When i asked what oil he put in he said motul 1o weight , he reckons he rang Triumph and they said motul is the choice oil and they use 7.5 , but 10 wil be better , , it did'nt work , and putting the brake on and pushing the bike up and down , theres a real clunk , i had done this before he came round and there was no clunk , but i will say i did'nt rock it has hard has he did ,
Anyway , i rode it back to his house for him to , give it a look over tomoro and see whats going on , but going off my drive it still felt like it had dropped into a 2 foot pothole , same going into his driveway , . It did'nt seem has bad with the po going .and on the way back i could'nt hear any clunking so i figure that might be the brake calipers clunking .
Now what has raised my eybrows a bit is reading on here has far has i can tell , its supposed to be 0 oil . i've also read that 667 mm of oil per fork , so based on that the oil is too thick , and what concerned me is , he brought the oil with him , and while he was trying to bleed the forks , pushing them up and down , he topped up one fork .
Since he done that i've read 667mm to fill an empty fork , but he still had some left in his , 1 litre bottle
667 mm times 2 = 1litre 300mm so if it was the same bottle its obvious theres not enough oil .Plus i'm a quick learner and if theres supposed to be a set amount , that would indicate , you cannot top it up unless measured somehow .
So does anyone know the excact amount needed , , and the thickness needed , , if it is too thick would that cause the bottoming out . . ..
I'm mechanicly illiterate , but i'm suss on this guy now , he reckons he's worked on rockets before , but i'm now doubting it very much , Any invo you can give will be appreciated , i would like to be armed with the right questions and answers , .
Giot a feeling the end result will be me demanding a refund and taking it elswhere .
