TEDS1
Standard Bore
- Joined
- Oct 23, 2009
- Messages
- 5
I have 2009 triumph rocket classic. It has a cat bypass pipe TORS and a K&N filter! Can anyone tell what they think should be the correct ecu map with current set up? Also I have recently replaced the Throttle position sensor switch due to a long standing issue! Occasionally and usually when I've given the rocket a thrashing it cuts out on deceleration, hence I've changed the TPS!! But it still cuts out now and again, last thing I need is the beast locking up that large back end!! Any of you guys have any ideas to either of these issues thx!
