DavidR3R
.060 Over
I'd really appreciate some help from you guys. For a while now the bike (2013 Roadster) would start to crank then pause, dead, before carrying on and starting as normal. Today though when returning from the shops, the bike did the usual sweep but with nothing happening when I pressed the starter button. I tried again and it did eventually start.
Later on at home, I tried again and nada... I checked and cleaned the starter button area and kill switch, all seemed ok but still nothing. Then I moved it out of neutral into second and back into neutral and it fired up no problems, totally normal.
So, question is, do you guys think it's the neutral sensor? If so, is it something I can easily look at and check to eliminate?
The bike is still just in warranty so I'm not keen to do too much myself if it should be a warranty claim.
Cheers,
Dave
Cheers,
Dave
