Dennsell
Top Fuel
- Joined
- Jul 5, 2009
- Messages
- 1,860
- Location
- Kawasaki Japan (Perth WA) (GY - UK)
- Ride
- Bonnie T 100, unfortunately not Rocket lll Country
Ha Ha........ only if you pay for the Airfare There and Back a note for you though, the bikes horn is negative switch so you need to run your positive relay switch wire directly to the horn wire and the negative relay wire to the horn source wire, memory fails me but I think I had to reverse the connections on the relay but it might be wise to check with an auto sparky, sorry but it was nearly two year ago and it is too dam hot to go and pull bike apart to trace wires to thier sources, if you connect it up as normal your horn will blow every time you turn on your ign
Hey thats no prob for a mechanic Hans
But thanks for the heads up..
Maybe won't need it now the Cats gone.. I can just use the throttle
PS.. you really disapointed me there Hans I thought you would have been happy to pay your own air fare as a gesture of rocketmanship
