Headlight Cut UNTIL start
Thank you for your fast answer my dear DEcosse.
All is right and works fine now.
My relay was defect with a permanent contact between 30 and 86!!
i bought another one and it's ok.
Yes i've got HID and glad to do this mod.
Thank's again.
... My relay was defect with a permanent contact between 30 and 86!!...
Oh wow! That would have been the last thing I would have expected - how bizarre!
But glad you got it sorted out and it works as advertised! :p
Enjoy!
now when I return home I want to mount my GPS snug inside the small wind screen for obvious reason therefore I want to go keyless ignition start anybody has installed a RFID keyless system ?
RFID or LED Remote work the same. The drawback is the distance of the RFID read. only a couple inches.
DEcosse has posted a setup that uses an rfid alarm that is better range and adds the alarm feature too. That install is on the rat site.
Keyless Ignition - Part Deux! - Triumph Forum: Triumph Rat Motorcycle Forums
And we discuss all three options on the rocket here:
Keyless Ignition. - Triumph Forum: Triumph Rat Motorcycle Forums
I have a question
When I start my 2010 Roadster the lights go out and then come back on after the engine has started. Is this not true with most stock motorcycles?
EDIT: Never mind I read it incorrectly
I will be installing an LED headlight in place of the OEM headlight. I will also be doing the same for the passing lights. Which of these mods would you recommend for LED headlights, non-HID or HID?
You guys may be interested in the Headlight Cut Modification I designed
This is for bikes without a headlight control switch - this fairly simple mod will keep the lights off completely until after it is started.
Currently, when the ignition is initially turned on, the headlights come on immediately.
Triumph incorporated a 'cut while starting' feature however, so that the lights go off while the starter motor is engaged.
But here is a fairly simple modification that takes it a step further
- by adding in one more relay, the lights will remain off completely until after the starter is pressed and released.
(note that lights will not come on until the button is actually released, not when initially pressed)
This is actually a great feature for those of you using TuneECU - there is no need to pull any fuses when this mod has been installed.
Total cost will be less than $10
You need one 12V relay (20A minimum rating), Three* diodes and some wire - that is it!
* If you use a relay that already utilizes suppression resistor or diode, you will only need two diodes
How it works:
When ignition is first turned on, the new relay will be 'off' inhibiting power to the OEM starter relay.
When the starter button is pressed, the new relay will energize along with the OEM starter relay, completing the circuit through both relays to the starter solenoid.
When the starter button is released, the 'new' relay will remain on however - it will self-latch because of the connection from its output (87) through the diode (D2) back to the input (86).
The diode (D1) in the starter line prevents the current from flowing back to the starter relay, otherwise it would keep the starter relay energized.
i.e. this diode allows the starter signal to flow to the new relay, but not from the new relay to flow back to the starter signal.
And when the starter button is released, the OEM starter relay de-energizes and switches power from the now-latched new relay, to the headlights.
The new relay will remain latched on as long as ignition switch is on - will reset when ignition turned off.
The diode (D3)* is added across the coil for turn-off spike suppression (good practice when adding relays for ANY purpose)
*D3 not required if using a relay with internal suppression (diode or resistor) already
This will make for minimal drain from battery when you first turn on ignition. Also useful for those maintenance activities (like TuneECU for example) where you might want to have the ignition on, but not have lights on.
attachment.php
Note that you can omit the Suppression Diode (D3) between 85 & 86 completely if you use a relay that has a diode (or resistor) already installed.
The suppression diode is not integral to the actual circuit mod, but good practice when installing any relay in any application (often omitted!)
Here is step by step process on how to wire the original (above) up
(make the appropriate changes if doing the HID circuit at the bottom)
All you need is a relay, socket (ideally) and three diodes.
I like to use the compact Panasonic relays - good for 20A and much smaller/neater form factor than std. Automotive style relays.
You can also use the Omron style relays used as OEM - also compact (and OEM has built in resistor so can skip D3)
But a Generic 4 terminal automotive relay may also be used. (or even 5 terminal - just ignore the 87a centre terminal which will not be used)
Just be sure to identify the terminals appropriately for whichever relay you end up using.
I would advise a 20A mimimum rated device
For diodes (for example)
In US - from Radio Shack Model: 1N5399-S RS Part #: 276-1114 - 1N5399-S Silicon Diodes (3-Pack) - RadioShack.com ($2.19 for pack of 3)
In UK - from Maplins - 1N5404 - Part # QL84F (£0.29 ea) or 1N4007 Part # QL79L (£0.24 ea) Link Removed
Step 1.
Prep first relay terminal by joining the three* diode cathodes (ends with the white stripe) together and crimping/soldering.
This terminal is for the 86 location in the relay socket
* Note that if your relay has built-in suppression diode or resistor, you may omit D3 and only require two diodes (see step 5)
attachment.php
Step 2.
Crimp/solder the Anode of ONE of the three Diodes and a 14 ga wire together to another Terminal.
This terminal is for the 87 location of the relay socket.
(This wire will be the Output wire ultimately connecting to the OEM start Relay input)
attachment.php
Step 3.
Connect the Anode of another of the three diodes to an 18 ga wire.
(This wire will ultimately connect to the White/Red starter signal wire)
attachment.php
Step 4.
Heatshrink over the diode and wire from step 3
attachment.php
Step 5.
Crimp/solder the Anode of the remaining Diode along with an 18 ga wire together to another Terminal.
This terminal will be for the 85 location of the Relay Socket
(This wire will be the Ground wire for the relay coil ultimately connecting to a common ground reference)
* If a relay utilizing built-in suppression is used, connect the ground wire directly to the termnal without the additional D3 diode
attachment.php
Step 6.
Install the three assembled terminals into the 87, 86 & 85 locations of the relay socket.
Of course plan ahead for whatever relay/socket you are using to ensure the correct locations are selcted.
attachment.php
Step 7.
It is critical that the two exposed Anodes do not touch!
These should be physically isolated from each other and coated with something like liquid tape or heatshrink over the idividual components.
attachment.php
Step 8.
Final step can be to tidy with heatshrink sleeve.
attachment.php
Installation:
1. Remove the Blue/Yellow wire/Terminal from the input to the OEM Starter Relay and insert this wire/terminal into the remaining open location (30) in the new relay socket
2. Attach a Terminal to the Blue Wire and insert this in the OEM Starter Relay socket location from which Blue/Yellow was removed in step 1
3. Attach the starter wire from the new relay to the white/red wire of the OEM Starter relay (if your relay has two white/red wires use the one on the input side i.e. from the start switch)
4. Connect the black wire to a ground circuit wire (any) or battery negative.
Test:
1. Test without starting:
Turn on Ignition, lights should remain OFF;
Press 'Start' button (NO clutch!) and hold - lights should still remain OFF;
Release 'Start' button - lights should come ON.
Turn off Ignition - Lights should go OFF.
Turn Ignition back on - Lights should remain OFF (until 'Start' pressed/released again).
This procedure (Start button/no clutch) may be used at any time if you wish to turn on lights without starting.
2. Test with starting:
As per Test 1, but this time pull clutch lever which will also start engine.*
Lights should remain OFF BEFORE AND DURING start, then come ON when button is released.
If you stop 'crank' before engine fires, lights will actually come ON when button is released
- however should go OFF again when 'Start' pressed again (as per pre-mod condition) and back ON when 'Start' released.
Alternative scheme for HIDs:
With the original scheme above, there may be a very small instant as the relays first switch states where the lights comes on for a few milliseconds - this is just due to the finite time it takes for the electromechanical relays to change over.
This is really inconsequential when operating with incandescent bulbs.
However if using HIDs, it would be preferred not to have even this minimal power duration to them
This modified version will work for that situation and will not power the HIDs until after the start process is completed.
It can also be used for non-HID application if desired, but the added complexity (albeit minimal) of the capacitor is not necessary for incandescents.
Note that this one is AFTER the start relay, vs the original which is before.
Because of that, the capacitor must be added to ensure that the relay remains on momentarily after the start button is released, to ensure that the relay will latch.
Also note that this revision may also be used for non-HID if preferred - however the downside is the added complexity (albeit minimal with the capacitor) but also that the pre-start turn-on (as explained in Test 1 above) will not work with this rev - the clutch lever must be pulled and the start relay energized (i.e. powering the starter) in order to complete the cycle to turn on the lights.
attachment.php
*small caveat - neither has been specifically tested on a Rocket - however has been proven on other Triumph models that utilize virtually identical scheme.
You are a legend, thank you for sharing this
Wow - I've really been hanging out with you guys for this long?? :D
... Which of these mods would you recommend for LED headlights, non-HID or HID?
Non-HID
I don't think anyone is using HIDs these days - the problem is moreso with HIDs because their module does not respond well to turning off and then on again before it gets fully hot.
And the initial circuit will still have a (albeit barely noticeable) flicker as it first turns on.
Anyone with HIDs should certainly incorporate this, although again, don't think anyone is doing these HID conversions any more (or shouldn't given the advent of quality LED sources)
@Mittzy - let me take a look at this again with respect to Roadsters - that already has a second relay so might be able to utilize that without having to add an extra
(that is a bit speculative at the moment, need to take a look to see if it's possible so not 100% on that yet)
Oh yes! Definitely quite simple mod for the Roadster without having to add an extra relay!
It's essentially just copying the scheme for the HID circuit but without the need for the capacitor - in the Roadster scheme you just use that second relay and replace the Red/Blue wire into the 86 terminal with the starter signal coupled from the adjacent starter relay (utilizing the diodes as per the scheme shown earlier)
I'll do schematic and full instructions for it later (sooooo backed up right now!) but that is essentially it. All you need are couple of diodes and a modest bit of rewiring.
On a Classic or Touring you would still add the second relay and incorporate the diodes giving you BOTH the Ignition Bypass AND the Delay-Till-Start feature all in a single relay mod.
Certainly for LEDs this is the only way to go (the full dual relay kit is a bit overkill for LEDs but for Std Incandescents they will give you a bit of headlight improvement)
OK - here is the mod for the Roadster - just need a couple of diodes, a capacitor, short piece of wire and some new Relay Socket Terminals.
For a Classic (or Touring) -it's essentially the same, but you have to add the relay and a fused supply as well as parts listed for the Roadster mod.
This Mod will accomplish BOTH Key-Switch Bypass AND the Off-Till-Started Mods in a single relay addition.
How these work:
When you turn on the key, the Headlight/Starter Relay is not energized and supplies power via the Normally-Closed contact over to the Second Relay (new or OEM Headlight Relay as appropriate to model); however the Second Relay is OFF at this point, so no power goes out of the Second Relay to the Headlight(s).
Operate the starter button - the Headlight/Starter relay energizes and transfers power away from the output going to the Headlight (or new) Relay, and out to the Starter Solenoid.
Simultaneously, the Second Relay energizes - however since there is no input power to the 30 terminal at this point, the headlights remain off.
Now release the Start button - the Headlight/Starter relay restores power to the 30 terminal and the second Relay latches on.*
*Edit - I've just realized in writing the explanation of how works, that there could potentially be a 'race' condition here - to resolve that, it would require addition of a small capacitor between the 86 & 85 terminals which would ensure the second relay latches. (this would be as per the earlier HID circuit) - The capacitor ensures the second relay remains on while the first relay is restoring power to the 30 terminal. It MIGHT work without the capacitor but it depends on the speed of the respective relays - the cap ensure it would reliably work every time.
