BenchracerBob
.040 Over
Triumph make a cable that will allow you to connect to 12V (via fuse #3) and earth. Fuse #3 has a uninterrupted 12V and is not dependant on the ignition key.
The cable part number is A9938065 (GPS Connector kit).
You will need to raise the tank to find the connector, and then remove the blanking cap from the connector. The connector in question is just to the left of the yellow #1 (Front is to the left)
