If it's cranking, can't be the ignition switch skydog1000
You should certainly check for spark but I'd be looking towards fuel, especially if it's been laid up for quite a while.
It's really pretty much the same systematically as your Sprint, just scaled 'up'
Is Neutral light on? (you can raise the side-stand switch to eliminate that as contender)
Do you hear fuel pump priming?
Checked for Injectors spraying?
If you get spark, you can spray starter fluid into the TB's and see if you can at least get a 'cough'
(You can even try that without checking for spark - if it does kick, then you confirm is fueling issue)
