I bought a fob off E bay i lifted my seat and there was a limit switch, i shorted both wires to the positive on the battery and follow instructions below. It worked took me 5 mins hope this assists.
not much help, boys better off going to a harley site hahaha
1. Turn off the Motorcycle Ignition
2. Ensure the alarm is disarmed by either a key
fob or PIN entry.
3. Make a connection between the two wires to
the Protective Trigger Switch and the
motorcycle battery positive terminal
4. Turn on the Motorcycle Ignition
5. Wait for one beep, one flash of the indicators
and the alarm LED to illuminate
6. Press circle button on the transmitter. The
alarm will beep once if the new code is accepted
7. Wait 5 seconds
8. Press circle button on the transmitter again.
alarm will beep twice if new code is verified
9. Turn off the Motorcycle Ignition
10. Remove wire from battery positive terminal
& Protective Trigger Switch.
11. Arm and disarm the alarm from this new key
fob.
12. Note! The system will only store the codes for the last 12 fobs,
