The following is what I answered you in another recent post regarding car tire 225/55-16.
Looks to me to be within an inch the same diameter as an OEM 240/50R16.
Should not affect your ABS assuming you still are running the OEM front size of 150/80R17.
I did the calcs awhile ago, but as I remember the circumference difference needs to exceed 8% of OEM for the ABS to stop functioning. I run a slightly larger rear Excedra Max at 240/55R16 and with a 130 front the ABS stopped functioning. I can get away with a 140 up front and retain ABS function.
