First off my 2005 R3 is stock (the engine anyway) has 35,000 miles and had the output shaft bearing replaced at 13,000 miles. It feels like the universal joint in the drive shaft is bad (but it isn't) and it it is very annoying to ride at low rpm because of the jerky feel from the extra drive line slack. I am assuming it's a weakened spring in the torsional dampener but I can't be sure, anyone else have a similar issue?
My other issue is my clutch (which may be contributing to my other problem) if you try to let the clutch lever out slowly it is very jerky and can me a pain in the a$$ at low speed in a parking lot. Also I tried to adjust the clutch and the lever travels more than it should, if I adjust it one way it will slip and if adjust it the other it won't fully disengage. I am assuming the lifter and shaft are worn which in turn gives me my longer than normal clutch pull. I plan on putting in a new clutch, springs (both Barnett), lifter and shaft. Do I need to upgrade the pressure plate and bearing as well?
When I do the clutch I want to do everything at once and have all the parts here and ready to install so my bike isn't sitting apart for a month or two waiting. I figure once this is taken care of I can see if the drive line slack problem is better or worse and then figure out what to do about that. Thoughts?
