I usually leave the hos on the water pump and pull the face of the pump off this allows more of the coolant to drain out. then I apply Hylomar sealnt to the gasket sfurcae and install the cover back on. Fill her up bleed her (there is a bleed screw right above the thermostat housing which allows you to bleed the air out of the head) and down the road I go
