Dyngoo
Standard Bore
Sorry if this is a bit picture heavy.
I have just started to fit the Fog Light Kit (A9938085) to my UK spec 2010 R3T which I bought on eBay (new & unused). I have since found out that I have the US kit and appreciate that this may be the reason for my problem!
All went well until I got to instruction 47 on the manual :-
The problem is that the only 3 pin connector on the main harness doesn't fit with the accessory loom provided with the kit (A9930147/2) as it is a different shape.
Bike Loom
Accessory Loom
The wire colours seem correct (Blue / purple/ black) however. the order of the wires is different between the accessory loom and the bike (see pics).
Bike Wire Connections
Accessory Loom Wire Connections
Has anyone come across this sort of issue before?
Will I be OK in breaking the accessory loom connector and simply connecting the wires to the bike loom in the correct order?
I have read how poor the R3T electrics are and don't really want to do something that will make them worse!
Any help or guidance would be appreciated.
Thanks
Bike Loom
Accessory Loom
Thanks
