ConcreteBob
Ok so I have been reading around on this forum about the idle issues. It seams that since the Triumph fix its only gotten worse. No tune fixes it for more than 5 miles.
So here is the rundown of whats going on. On certain tunes like the stock triumph tune with the Triumph OR pipes and catbox removed, the idle will be ok sitting but while out riding it will not come back down unless you pull the clutch in. It will hang around 1500-2000 so you can mantain 55-60mph lol. If you break and bring it down then it will finally drop. With some of the richer tunes to get rid of the popping on here usually the idle will go way to low to keep it running until its started with the throttle open and eventually it will continue to run but it cycles from almost dying to normal speed idle.
I can usually get the bike to idle correctly by going into the tuneboy program, status screen, and resetting the ICSV with its 4 step process. It never drops completely to .60V but it usually is only .2-.4 above .60v. After I do this the bike will idle like butter and will ride ok for a few miles but usually the high idle problem will show its ugly head. Once returned and rehooked up the Throttle position will read sometimes around 1.3 instead of 0 even though the cables are adjusted correctly and when reset it goes back to 0 like normal.
Im guessing it would be good to just take it to the dealer with laptop in hand and show them what im seeing and doing and see if she can check it with her triumph device and get the same numbers. Then SHE needs to ride it and see for herself what is going on with the high idle or if it happens again, the low idle.
Its almost as if the ECU relearns itself and instead of working better it just turns to garbage. It would almost be best if it could be removed from the equasion and just run at default the whole time.
I have done the 12min idle process a few times though but Im guessing we need to reset everything and do it once when the bike is true cold.
Still this problem is getting seriously anoying and my Dad who is the main rider of this bike is about |--| <-- Close to just going nuts. We have been to the dealer twice to adjust the stepper motor and every time its always better for a short while then it goes back to crap. Im guessing either the TPS is bad, Stepper motor is bad, or something inbetween since the TB's are synced and the bike runs ok when your into it and such.
